Re: What type of oil should I use in my Hydralic system.
Posted by Will@ont.ca on December 28, 2001 at 02:42:43 from (216.58.67.118):
In Reply to: What type of oil should I use in my Hydralic system. posted by Brian Coates on December 27, 2001 at 20:17:03:
Brian,I use {NON-Detergent 20}motor oil,you can use hydraulic oil but its a little more $.There are two plugs pertaning to the Hydr-unit."sitting on the tractor"..on the left side of the hyd-unit there are two plugs 1 lower one for draining the system and 1 high one for filling it up.It has a tube type filter on the back of the unit its take about a 1 inch wrench to back it out.It's made of steel mesh,I just clean it up good an put it back in.BE careful of the washer gaskets on the plugs and stainer and you can re-use them.Happy Newyear!! Will
Post A Followup
: Re: Re: What type of oil should I use in my Hydralic system.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
