Re: What type of oil should I use in my Hydralic system.
Posted by Haas on December 28, 2001 at 05:10:17 from (129.37.117.254):
In Reply to: What type of oil should I use in my Hydralic system. posted by Brian Coates on December 27, 2001 at 20:17:03:
Use HyTran Fluid in your Super A hydraulic unit. When you drain it, be sure the rockshaft arms are in the rear position so that the cylinders are fully retracted. The manual says to briefly run the engine after you have drained to get as much oil out of the pump and lines as possible. The Strainer is on the LH side, bottom held in by three cap screws. Best to get a new gasket before you take it out. Clean the strainer in clean solvent such as kerosine. Very Important that everything is VERY CLEAN. When you refill, make sure the rockshafts are still in the rear position and then fill up to the bottom of the fill hole. Start the engine before you put the plug back in and work the touch control levers back and forth to reprime the system and work out the air. Then with the rockshafts in the rear position, fill back up to the top of the fill hole and install the plug. Good Luck!
Post A Followup
: Re: Re: What type of oil should I use in my Hydralic system.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
