Re: OK - I want everything in a tractor...
Posted by jmyt_47 on December 28, 2001 at 07:43:33 from (170.92.1.104):
In Reply to: OK - I want everything in a tractor... posted by Gibby on December 28, 2001 at 07:30:52:
I have a 300 too. I think the belt/pto HP is 40, and the drawbar HP is 30. So you should be good with that pto generator.
Check the link out:
Post A Followup
: Re: Re: OK - I want everything in a tractor...
