Re: OK - I want everything in a tractor...
Posted by Steven@nd on December 28, 2001 at 08:48:53 from (12.23.184.113):
In Reply to: OK - I want everything in a tractor... posted by Gibby on December 28, 2001 at 07:30:52:
Not that I recommend it, but my Farmall A will run quite a bit of the farm on our 35kw generator. At least in the summertime it will run the TV's and fridges and the well. Winter is another story - when every tank heater, etc. is plugged in our 1086 will bark on the generator. 1086 was putting out 145hp on the dyno when overhauled and I bet it has more now that it is broke in. Those generators take a lot of power.
I don't think you should have any trouble with your 300 if you don't have too many tank heaters.
Steven
Post A Followup
: Re: Re: OK - I want everything in a tractor...
