Re: Re: JACK STANDS
Posted by william on December 29, 2001 at 01:34:01 from (12.93.44.151):
In Reply to: Re: JACK STANDS posted by Larry on December 28, 2001 at 21:04:17:
The one that I remember were home made. Not really jackstands, they bolted to the tractor to make them stable. Just a piece of bar for an axle, two wheels, and four pieces of angle iron, two on each side. The angle irons fit loosely on the axle so they could open out and bolt as wide apart as possible and give the right height. Not hard to make.
Wm
Post A Followup
: Re: Re: Re: JACK STANDS
