Re: leaked, but stopped for now
Posted by Larry on December 30, 2001 at 10:34:11 from (216.202.132.34):
In Reply to: leaked, but stopped for now posted by Jack on December 30, 2001 at 06:27:02:
Jack..Before you pull the head and replace the gasket check the themostat. A stuck thermostat will cause excessive pressures which could push radiator fluid out a between a cold block and head that is not properly torqued. As the block heats up it may expand enuf to stop the leak but you will still have the pressure problem. Often simply retorquing on an old gasket will not work and you'll need to replace gasket anyway. I'd try the simple stuff first. Just my .02$ Good luck.
Post A Followup
: Re: Re: leaked, but stopped for now
