Re: My C runs cold
Posted by Farmer Bob on December 30, 2001 at 15:12:03 from (66.152.73.139):
In Reply to: My C runs cold posted by Randy on December 30, 2001 at 15:04:57:
Randy, You can either put a cover over the grille while the tractor is warming up to check if the gauge moves off of cold or pull the sensing bulb on the end of the gauge wire out of the thermostat housing and stick in a pan of hot water. If the gauge moves, it probably is working okay.
The C113 engine does not really heat up with the tractor just sitting running. You'll have to go out and do some work with it to get it up to normal operating temp.//FB
Post A Followup
: Re: Re: My C runs cold
