Re: Cub Clutch Won't Disengage
Posted by gene b on December 30, 2001 at 16:40:49 from (63.15.134.51):
In Reply to: Cub Clutch Won't Disengage posted by george on December 30, 2001 at 12:29:58:
could be the pilot bng in the crank is dry did you put a little lube on the pilot before putting back together
Post A Followup
: Re: Re: Cub Clutch Won't Disengage
