Anti Freeze @ Head Gasket 44 A
Posted by EZHangin on December 31, 2001 at 15:01:51 from (216.211.32.2):
Happy New Year fellow Farmallers!
I took the 44A out for a last ride in 2001, I was gone about 15 minutes down the road when it started to miss and I thought I was running low on fuel, but alas that was not the problem, it suck-holed all the way home.
When I got it back into the garage I noticed a bit of Anti-Freeze seeping out around the head gasket. Not alot mind you, just a few wet spots on the plug side, mostly near the #4 plug, but definitely coming through the head gasket. Could this be a sign of a cracked head?
If so, could it be getting into a plug hole and causing the missing?
Post A Followup
: Re: Anti Freeze @ Head Gasket 44 A
