Re: Should I install valve seals on an M Head ??
Posted by The Red on January 01, 2002 at 04:31:29 from (12.84.239.121):
In Reply to: Should I install valve seals on an M Head ?? posted by cheg on December 31, 2001 at 16:12:18:
Cheg I would not. Those stems need lubrication.
Post A Followup
: Re: Re: Should I install valve seals on an M Head ??
