Re: Farmall M Starting problems
Posted by Red Dave on January 01, 2002 at 17:54:29 from (63.17.102.87):
In Reply to: Farmall M Starting problems posted by Joe on January 01, 2002 at 17:20:07:
It's likely due to a high resistance either in the connections to the switch or the switch itself.
Clean up the connections first, it's quick, easy and doesn't cost anything. Make sure they are clean and tight. Sometimes new lugs on the ends of cables makes all the difference in the world.
If that doesn't fix it, it's probably the switch itself, over the years the contacts inside get burned and pitted and don't make good contact anymore.
Post A Followup
: Re: Re: Farmall M Starting problems
