Re: Farmall M Rebuild
Posted by justin on January 02, 2002 at 08:32:47 from (216.188.199.193):
In Reply to: Farmall M Rebuild posted by Phil - New to Farmall on January 02, 2002 at 08:04:36:
The sleeves can be removed with the crank in place.. As far as a sleeve puller is concerned, check with your local dealer, they may lend you theirs to use, or atleast loan you the puller plate.. For HP, either use IH Firecrater piston & Sleeves, or M&W Pistons and Sleeves.. Both will give you the same HP. The link listed will show you the HP increase with firecraters.
Post A Followup
: Re: Re: Farmall M Rebuild
