Re: farmall industrial A tractor
Posted by Ken Williams on January 02, 2002 at 15:35:45 from (63.93.0.116):
In Reply to: farmall industrial A tractor posted by Tom Welch on January 02, 2002 at 12:07:21:
Tom; The industrial A has a foot throttle, in addition to the hand throttle. The front axle is also made of heavy, square tubing, and is adjustable. The serial number prefix for the industrial A is " IAA ", instead of " FAA ". I hope this helps you. (P.S. The foot throttle is located on the platform, with the clutch, and the brakes, on the right side of the brakes.)
Post A Followup
: Re: Re: farmall industrial A tractor
