Re: Re: substituting hydraulic fluid
Posted by the tractor vet on January 02, 2002 at 19:48:54 from (216.196.13.156):
In Reply to: Re: substituting hydraulic fluid posted by Glenn(WV) on January 02, 2002 at 19:43:00:
If your seal is leaking then i would say that the bushing in the pump has enough ware that it is allowen the pump shaft to wobbel you may get lucky buy replacing the seal but i think that it will leak again before long . Myself i hate to do the job twice and i would not change oil stick with Hy Tran or it's replacement.
Post A Followup
: Re: Re: Re: substituting hydraulic fluid
