Re: Farmall H engine rebuild questions...
Posted by Zonie on January 02, 2002 at 19:59:27 from (64.12.103.154):
In Reply to: Farmall H engine rebuild questions... posted by Steven@nd on January 02, 2002 at 16:01:44:
Steven,
I just finished overhauling my H and used the 3 7/16 over bore fire crater pistons and sleves.
The tractor will pull the front tires in the air while pulling a hefty pile of dirt with my 3 point back blade in 3rd gear! I had to weight the front tires with water to keep it down. and I had to weight the back tires 1/2 full of water also due to the 1 set of wheel weights are nowhere near enough to keep the back from slipping. I used mostly Case /IH parts and Bermuda Ken (@ Carter and Gruenwald)can go visit Bermuda again courtesy of me! no really I found Ken's prices weren't much , if any , more than the Tisco's kits.
Post A Followup
: Re: Re: Farmall H engine rebuild questions...
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
