Re: 6 volt battery's compared to 12 volt batteries
Posted by the tractor vet on January 03, 2002 at 10:25:18 from (216.196.12.80):
In Reply to: 6 volt battery's compared to 12 volt batteries posted by greaseman on January 03, 2002 at 10:01:40:
More then likely it is because with the old charging systems that the battery does not get charged all the way up because you don't run the tractor long enough and when you are only putten out 6 to 10 amps charge it just gets a surface charge , On my S/h i have the reg .set up and it will charge up to 27 amps and even with the lites on i still get 10 amps charge and the battery has been in there for 5 years now and unless someone leaves the lites on or the ing. switch out it will alway start down to 30 below just don't ask it to start at 35 below it won't do it and besides it's to cold for me to be out there.
Post A Followup
: Re: Re: 6 volt battery's compared to 12 volt batteries
