Re: torque on bolts
Posted by Theman on January 03, 2002 at 12:08:00 from (12.19.86.5):
In Reply to: torque on bolts posted by mel on January 02, 2002 at 04:28:44:
You didn't mention what model you are working on so I can only give you a rough idea. With the clutch assembled in the tractor, start by leaving about 3/16" clearance between the fingers and the throw-out bearing. You may then have to adjust your clutch pedal linkage to give 1" to 1-1/2" of free travel before the fingers contact the bearing surface. The goal is to ensure the fingers don't drag against the bearing with the clutch completely engaged.
Post A Followup
: Re: Re: torque on bolts
