Re: Farmall A Rear Wheel Bearings
Posted by Hendrik on January 04, 2002 at 01:43:04 from (194.53.253.50):
In Reply to: Farmall A Rear Wheel Bearings posted by Sketcher75 on January 03, 2002 at 19:56:37:
The whole rear axle assembly of bearings, spacers and the bull gear is held together by a bolt that goes in the inside end of the axle. This bolt seems to have come loose and probably lies in the oil pan of the final drive. An exploded view is in the tractor's parts book. I got mine from Binder Books and am very pleased with it. The bearings are cheap because they are standard ball bearings. Buy new seals as well, while you are at it. Check the right axle too! Good luck. Hendrik
Post A Followup
: Re: Re: Farmall A Rear Wheel Bearings
