Re: IH 230 rebuild
Posted by Larry on January 04, 2002 at 01:54:25 from (216.202.132.34):
In Reply to: IH 230 rebuild posted by TerryC(MO) on January 03, 2002 at 20:33:31:
Terry - You kinda answered your own question in that you really won't know what you have 'til you open her up. I would guess from your description of things that a piston/sleeve replacement and top end job are in your future. My .02 is that you should also have crank, camshaft, and oil pump at least checked. Actual teardown and replacement is not hard..go slow...label everything...keep it organized. If you have a friend (machinist) or can take engine to machine shop it will save you money and headaches to get good advice the first time. You don't want to reassemble everything and discover you got wrong size bearings or should have had that crank turned when you had the chance. Good luck
Post A Followup
: Re: Re: IH 230 rebuild
