Re: Got my H home today!
Posted by Steven@nd with update on H on January 04, 2002 at 16:52:12 from (12.23.184.239):
In Reply to: Got my H home today! posted by Steven@nd on January 04, 2002 at 12:40:52:
Pulled it around the yard trying to break it loose, no go. Pushed it into the heated garage and tore into it. Things came apart rather easily. Found rusty cylinders, but only 1 piston stuck, the others move when I rock the wheel. Tomorrow a big hammer and a block of wood will get it loose. I'm going to hone the cylinders and put it back together since there is NO ridge whatsoever on the cylinders.
Best place to get a valve grind gasket set??
Steven
Post A Followup
: Re: Re: Got my H home today!
