Draw bar for a 560
Posted by Curt on January 05, 2002 at 19:38:45 from (12.253.102.126):
For the last two years I have been using my 1959 560D with a fast hitch mounted draw bar to pull a JD 14T baler. We just bought a newer JD 467 baler that has an equal angle hitch that requires a straight draw bar about 8" long to go into a receiver on the hitch of the baler. I was going to modify the fast hitch draw bar with a longer hitch plate, but the baler has a requirement that the hole in draw bar must be 14" from the tip of the PTO shaft. This requirement is impossible to meet using the fast hitch draw bar. Is there a standard draw bar that can be mounted on a 560? What did a non-fast hitch 560 use?
Post A Followup
: Re: Draw bar for a 560
