Re: Re: Re: Is it supposed to make noise?
Posted by bill on January 06, 2002 at 08:57:01 from (24.237.151.205):
In Reply to: Re: Re: Is it supposed to make noise? posted by Red Man on January 05, 2002 at 07:29:28:
If the seal in PTO is bad is this an easy fix? I was told if I pull out the PTO the shaft might drop out in the trany and I would have to break the tractor down. I have a framall 400 and it too makes noise when not engaged, thats also when all the oil starts pumping out the breather.
Post A Followup
: Re: Re: Re: Re: Is it supposed to make noise?
