Re: 6 VOLT BATTERY..USE IT OR LOSE IT?
Posted by Mike ISW on January 06, 2002 at 15:41:02 from (152.163.207.54):
In Reply to: 6 VOLT BATTERY..USE IT OR LOSE IT? posted by Courtland on January 06, 2002 at 14:21:48:
You very well may have a bad battery and it needs to be replaced. On the other hand it has been my experience that a high percentage of problems said to be a bad battery were something else i.e., charging system,draw on battery,regulator,etc. A 6 volt system on these tractors is very reliable. When they are maintained and working correctly. Mis-diagnosis of problems have given 6 volt system a bad name.
Post A Followup
: Re: Re: 6 VOLT BATTERY..USE IT OR LOSE IT?
