Re: Re: Are you using multi grade oils?
Posted by jdp on January 08, 2002 at 16:33:36 from (66.79.36.79):
In Reply to: Re: Are you using multi grade oils? posted by john d on January 08, 2002 at 11:58:12:
I couldn't have said it better myself. I do use a lot of 15W-40 instead of 10W-30, but either one is better than 30 weight. I wouldn't tell my worse enemy to put non-detergent oil in a tractor.
Post A Followup
: Re: Re: Re: Are you using multi grade oils?
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
