Re: leaking axle seals on H
Posted by Jon on January 08, 2002 at 17:15:57 from (63.168.241.139):
In Reply to: leaking axle seals on H posted by Kurt on January 08, 2002 at 17:01:24:
You can pump more grease into the axle, but the oil starts leaking after being used for a while. Those aren't that bad to replace. Just slide the wheel off the axle, pull the cap off and put a new seal and felt in. Just make sure the axle surface the seal is on is nice and smooth.
Post A Followup
: Re: Re: leaking axle seals on H
