Re: Re: M/400 engine question
Posted by John In Iowa on January 09, 2002 at 09:17:13 from (199.108.164.14):
In Reply to: Re: M/400 engine question posted by the tractor vet on January 09, 2002 at 08:19:41:
Yep, The blocks, cram, and crank are the same from the Super M to the 450. They did make some small change in the head, manifold, governor, and carb. The big difference was the size of the pistons and wrist pins. The Super M and the early 400 had 1.125” wrist pins and the later and 450 had 1” wrist pins. The super and the 400 came from the factory with 4” pistons and the 450 came with 4.125 pistons.
Post A Followup
: Re: Re: Re: M/400 engine question
