Re: What Kind of Solder For Radiator
Posted by Kendall on January 10, 2002 at 07:04:37 from (64.209.33.251):
In Reply to: What Kind of Solder For Radiator posted by John on January 09, 2002 at 18:38:27:
Always make sure what you are soldering is hot enough to melt the solder. Lots of folks that dont solder try to melt the solder and expect it to flow into the whatever they are trying to fix. Your work should be hot enough that the solder melts when it touches it. Scotch brite or sandpaper will clean it up and help the solder flow and stick. Good luck.
Post A Followup
: Re: Re: What Kind of Solder For Radiator
