Re: Farmall B Ring Gear
Posted by ScottyNY on January 10, 2002 at 13:25:42 from (128.59.123.240):
In Reply to: Farmall B Ring Gear posted by Roger on January 09, 2002 at 19:51:53:
I put a new ring gear from Case/IH on my Superc last summer. Had the same thought, but there was only the slightest bevel on one side, maybe, maybe not enough to make a difference. It works fine, though. Hasn't bound up with the bendix or given the least sass. I'd say if you can detect that slight bevel on one edge, face it out. If not, I doubt you'll have any problem facing it either way as long as your bendix is in reasonably good shape.
Post A Followup
: Re: Re: Farmall B Ring Gear
