Re: Water out the exhaust when motor is started
Posted by Steven@nd on January 10, 2002 at 14:21:43 from (165.234.131.175):
In Reply to: Water out the exhaust when motor is started posted by Dale on January 10, 2002 at 10:17:09:
All of our tractors (even the modern ones) will shoot some water and soot out after a good rain. Also even in colder weather when they are kept inside the condensation will make them shoot some water. I wouldn't worry about it unless you don't run your engine to operating temp.
Steven
Post A Followup
: Re: Re: Water out the exhaust when motor is started
