Re: Re: Re: Farmall H (water in rear axel)
Posted by Larry on January 10, 2002 at 19:30:29 from (216.202.132.34):
In Reply to: Re: Re: Farmall H (water in rear axel) posted by Olaf on January 10, 2002 at 16:59:55:
Olaf - The teflon pipe tape might help some. Keep deck bolts tight and your H dry as much as possible and you should have no problems. Before I had a barn I threw a tarp over mine just to keep it reasonably protected.
Post A Followup
: Re: Re: Re: Re: Farmall H (water in rear axel)
