Re: 230 update
Posted by ralph on January 11, 2002 at 07:15:52 from (65.45.140.159):
In Reply to: 230 update posted by TerryC (MO) on January 10, 2002 at 20:53:40:
TerryC: Did ya see the "tip of the day" on Jan 8th? That item (on left side under Research) had about everything one could do in checking bearings. Don't forget the oil pump. The C series has had many posts here about pump backplate warping causing some oil pressure loss. If engine did not use much oil, the oil control rings were doing their job. The size of ring ridge hints at how much wear rings have. Keep us posted. R.
Post A Followup
: Re: Re: 230 update
