Re: cranking W4
Posted by Dave_Id on January 11, 2002 at 10:06:19 from (63.27.107.2):
In Reply to: cranking W4 posted by Hal on January 11, 2002 at 09:36:03:
Procedure may be off some on timing. Loosen mag, push up against engine. Crank with finger in #1 spark plug, when compression pushes finger out of hole, continue cranking until your timing mark lines up. Pull mag towards you until the impulse deal clicks. Now its timed. Make sure rotor is pointed to #1 wire on distributer. When you had mag off to replace the points and condensor, it's possible to replace 180 degrees from correct position. Recheck by cranking it around to #1 compression stroke, when you hear it click, your timing mark should line up. Recheck your wires on distributer, it's easy to get them in the wrong rotation. Tighten the nut a little on the 45 degree main jet on carb, this will tighten up the packing a little.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
