Re: Farmall B w/ single front wheel
Posted by The Dukester on January 11, 2002 at 11:13:32 from (65.89.19.35):
In Reply to: Farmall B w/ single front wheel posted by WIfarmboy on January 11, 2002 at 10:03:24:
The tractor(most definately a row crop) should be restored as it is. Then drive it that way, if you don't like it you can get the two wheel narrow front set up and put it on easily. The one front wheel set-up worked real nice in narrow vegetable rows and other truck crops. in some situations the single rib tire is best, in others a multi-rib tire is best. There's always a reason of application for front end types on tractors.
Post A Followup
: Re: Re: Farmall B w/ single front wheel
