Re: Farmall B Magneto gears indexes - got it apart.
Posted by justin on January 12, 2002 at 15:44:53 from (209.23.152.144):
In Reply to: Farmall B Magneto gears indexes - got it apart. posted by Dave G on January 12, 2002 at 15:12:18:
If you look at the gear that the R & L marked gear drives off of, you will see that the top of two teeth are beveled. Since you have a gas, you will want to index the R marked tooth between the two beveled teeth on the corresponding gear. Hope this helps
Post A Followup
: Re: Re: Farmall B Magneto gears indexes - got it apart.
