Re: Re: M Cylinder Heads Milling
Posted by justin--with answer on January 13, 2002 at 13:42:34 from (209.23.152.144):
In Reply to: Re: M Cylinder Heads Milling posted by The Red on January 13, 2002 at 06:36:44:
With a low compression head, firecraters will do practically nothing. Firecraters were designed specifically for the high compression gas head. If you were wanting more power with the low compression head, you will need to find a set of 8,000' altitude pistons and sleeves for the specific fuel type the head was originally intended for.
Post A Followup
: Re: Re: Re: M Cylinder Heads Milling
