Re: Re: Re: M Cylinder Heads Milling
Posted by justin on January 13, 2002 at 13:46:34 from (209.23.152.144):
In Reply to: Re: Re: M Cylinder Heads Milling posted by Thunder on January 13, 2002 at 12:36:24:
M&W gear company made tractor upgrade parts for most tractors from the 50's to the late 80's.. The M&W pistons could give greater HP if the correct altitude piston was used in lower compression heads. The M&W and IH Firecraters develop the same HP in the high compression gas. One of the benefits of M&W P&S Sets, was the Jet Black Sleeve. These sleeves were oil impregnated, and were designed to reduce wear during engine startup.
Post A Followup
: Re: Re: Re: Re: M Cylinder Heads Milling
