Re: Allis Chalmers with added alternator
Posted by steve on January 13, 2002 at 18:10:53 from (204.246.222.47):
In Reply to: Allis Chalmers with added alternator posted by Dean Slavick on January 13, 2002 at 15:49:00:
normally they use the delco 10SI alternator. YOu should have a 1/4 inch nut with a big wire on the back of the alternator that goes to the positive terminal on the battery. There are two spade terminsla on the side in a straight line. the R or 1 terminal is probably the problem. It must be switched off or disconnected when the tractor is not running. When running it is connected to the batter positive post (thru a resistor ). Usually this wire runs thru the ignition switch, or a toggle switch. The other small terminal is the F or 2 terminal. YOu can connect it to the positive post on the back of the alternator (12 volt.) If you need a picture e-mail me. Good test is to pull the two prong plug off and see if the battery discharges overnight.
Post A Followup
: Re: Re: Allis Chalmers with added alternator
