Re: Re: Re: Now that its drained?
Posted by Steven@nd on January 14, 2002 at 08:59:45 from (165.234.131.190):
In Reply to: Re: Re: Now that its drained? posted by Zonie on January 13, 2002 at 22:12:30:
Two way hydralics are easy. I've done this with an M that had the belly pump. Take hose from pressure exit and go to your 2 way valve (mounted somewhere in easy reach). Take return line and go to the fill hole for the liftall, put a tee in the line so you can fill it without removing the hose. Use the 2 outlets on your new valve to go to the cylinder on the implement. Then all you have to do when you want to use it is tie the liftall rod back in the lift position.
Email if you have any questions.
Steven
Post A Followup
: Re: Re: Re: Re: Now that its drained?
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
