Re: How do you charge an 8 volt battery?
Posted by ron on January 14, 2002 at 09:34:33 from (155.226.255.42):
In Reply to: How do you charge an 8 volt battery? posted by cheg on January 11, 2002 at 18:32:48:
You need a source voltage higher than the battery voltage to do real charging. If you can afford it, go to a Radio Shack or other electronics supply and buy a DC power supply with variable voltage adjust. The small AC/DC power adapters will do just fine and they are not expensive, but you will have to get proper connectors attached to it so they can be clipped onto your battery terminals. Set the adapter or power supply to approx 10 volts and let it charge your 8 volt battery.
Post A Followup
: Re: Re: How do you charge an 8 volt battery?
