Re: Re: Re: I put Kerosene in my M - by mistake
Posted by Bob Kerr on January 14, 2002 at 13:54:58 from (64.12.103.181):
In Reply to: Re: Re: I put Kerosene in my M - by mistake posted by Andrew on January 13, 2002 at 15:48:21:
When I run kero I just run the K1 kero for kerosene heaters. Last summer at the Elnora IN show I ran a horsepower test with gasoline and K1 kero for fuel. The horsepower was the same for both, but when I ran the F-12 on kerosene, I had to lean out the carb by a 1/4 turn.Adding kero to gasoline won't be much benefit in power or economy since the oil dillutes and you have to change it more frequenty than if you run on gas so any money saved by the better economy is lost with oil changes. I just run kero to demonstrate its use at shows.
Post A Followup
: Re: Re: Re: Re: I put Kerosene in my M - by mistake
