Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: Re: engine tech
Posted by Farmall Gray on March 16, 1999 at 17:45:12:
In Reply to: Re: Re: Re: Re: Re: engine tech posted by stoke it on March 15, 1999 at 01:19:49:
I would say it depends on the track and what size
tires you have. On a power track with 15.5-38s I
would say probably not. It might on a loose track.
I have an MM U with 4-13/16 bore and 6" stroke
and it will spin 18.4-34s on a good power track in 3rd. A freind of mine has an M with 4-1/4 bore
and 6" stroke and it wont run 3rd on the same track with 18.4-34s. Our 3rd gears are about the same speed. His runs pretty good with 18.4-38s in 2nd gear though.
Post a Followup
: Re: Re: Re: Re: Re: Re: Re: engine tech
