Re: Re: Farmall M Shaft Seals
Posted by Haas on January 14, 2002 at 17:24:53 from (129.37.117.188):
In Reply to: Re: Farmall M Shaft Seals posted by Denny Frisk on January 14, 2002 at 10:57:44:
I think the is talking about the seals on the clutch and brake pedal shaft. There are seals on that because it goes through the transmission. I think you are refering to the the clutch release shaft which as grease fittings on both sides of the clutch housing and is a foot or two in front of the pedal shaft.
Post A Followup
: Re: Re: Re: Farmall M Shaft Seals
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
