Re: Farmall A water pump
Posted by gene b on January 14, 2002 at 18:19:27 from (63.25.166.233):
In Reply to: Farmall A water pump posted by Mike on January 14, 2002 at 15:12:39:
no not until the SUPER A but you can put one on get one that comes with a pulley you will have to put a longer fan belt on also might have to cut the shaft off so the fan will clear the shaft your best way will be to take the radiator off and then go back together might want to blow the block off real good as you must be having problems the blocks get plugged at the bottom of the sleeves and water cant flow thru the bottom and out the lower hose good
Post A Followup
: Re: Re: Farmall A water pump
