Re: Super H front end wobbles at road speeds????????????
Posted by Dick Davis on January 14, 2002 at 22:58:29 from (64.12.102.173):
In Reply to: Super H front end wobbles at road speeds???????????? posted by jrr on January 14, 2002 at 22:36:43:
Check the achives for lots of discussion on this subject. Sources of the problem include: u joints in the steering shaft, worm and segment gears in top of upper bolster, bearing wear in upper bolster, excessive wear in lower bearing/sleeves of upper bolster, worn wheel bearings, and possibly mismatched tires. Check the ease stuff first and you will probably find it is a combination of some or all the items listed. Good luck. Dick
Post A Followup
: Re: Re: Super H front end wobbles at road speeds????????????
