Re: 1951farmall c
Posted by J3nut on January 15, 2002 at 05:21:10 from (205.188.197.178):
In Reply to: 1951farmall c posted by don hopson on January 14, 2002 at 21:13:01:
I was planning to change the front crank seal while I am doing my restoration but it looks like it would be a lot of work. I already have the whole front end off the engine but I think the pulley is pressed on and could be a bear, not easy like the rear crank seal.
Post A Followup
: Re: Re: 1951farmall c
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
