Re: Super H front end wobbles at road speeds????????????
Posted by shannon on January 15, 2002 at 10:40:05 from (146.186.68.29):
In Reply to: Super H front end wobbles at road speeds???????????? posted by jrr on January 14, 2002 at 22:36:43:
i have had this problem in a 350 and 450. the linkage play is not reallly that much of a problem when it comes to "wobble-wheels." there are two bearings in the front bolster(the funny shaped piece of cast iron that bolts to the frame rails and which the wheels are bolted to) that go bad. to fix it take the front wheels off, take the round gear off the top of the bolster and drop the front axle out the bottom. there will be a small bearing at the top and a large bearing at the bottom. while your at it you can replace the bushings for the rod that has the worm gear on it. to do this disconect the steering linkage, unscrew the cap on the front of the bolster and pull the rod out. all bushings can be taken out and put in with a properly matched piece of metal rod or pipe. this corrected the wobble in the 350 and 450 and now the only remaining play which amounts to one half inch in the steering wheel comes from the universals.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
