Re: Re: Can a H pull a 3 bottom plow
Posted by Denny Frisk on January 16, 2002 at 07:54:48 from (12.4.181.2):
In Reply to: Re: Can a H pull a 3 bottom plow posted by Hugh MacKay on January 15, 2002 at 18:40:05:
Around where I grew-up plows pulled really hard. One spring I watched the neighbor pull two #60 or #70 IHC 4-16's, one with a brand new 4020D w/Powershift and the other with a 756 Farmall with the German D-310 diesel. The 756 was running faster than the 4020! Course i also heard the 4020 later was pulling 3-14's in some REAL NASTY sod that hadn't been plowed for years... Dad tried 5-14's with His 4010D with the 4020 Kit in it. We had better performance after We pulled the back bottom off. Could run in 5th in corn ground and 4th in old hay ground. True 4020's could run a little better because they had the Diff. Locks.
Post A Followup
: Re: Re: Re: Can a H pull a 3 bottom plow
