Re: IH -240 Utility Tractor
Posted by Fred Mills on January 16, 2002 at 12:18:15 from (216.93.30.169):
In Reply to: IH -240 Utility Tractor posted by Jeff Harshbarger on January 16, 2002 at 06:59:50:
I think you'll like your 240; it is a gutsy little tractor and did good in contest with other tractors in its class. Nebraska test number 668 showed 30.82 pto hp and 28.07 drawbar at 2000 rpm.The 240 used a 122.7 cu in engine. I believe it has live pto and hydraulics(my 340 does). Parts may not be as available as for some tractors like the 8N. Manuals are available from Binder Books at 503-684-2024. Red Power Magazine is a great source too at 712-364-2131.
Post A Followup
: Re: Re: IH -240 Utility Tractor
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
