Re: International 574 D239 Wrong pistons
Posted by Les Repair on January 16, 2002 at 16:46:29 from (206.28.174.81):
In Reply to: International 574 D239 Wrong pistons posted by Bob D on January 16, 2002 at 12:15:14:
COMPRESSION. Get the valves and seats up to specs (or better). As OLD DUTCH said, the replacement pistons are lower compression. The new Case IH would be the same. Also not helping the compression, the new head gasket is probably different from the original, and likely thicker. Give me a call 641 847 2731.
Post A Followup
: Re: Re: International 574 D239 Wrong pistons
