Re: Rust in fuel tank
Posted by FC on January 17, 2002 at 07:40:55 from (208.14.16.15):
In Reply to: Rust in fuel tank posted by Old iron farmer on January 17, 2002 at 04:55:37:
I used a length of fairly heavy chain dropped into tank to knock loose scale. Quite a bit of work, but after this, and a through cleaning it has been ok since. I did watch sediment bowl and had to clean it and screen a few times afterwards, but it cleared up. I did not seal tank. Probably would work better if you did, but I keep plenty of fuel in there now, and haven't had any problems. Someone a while back mentioned temporarily removing the sediment bowl, and installing an inline filter you can see into and cleaning it often until it clears up then reinstalling sediment bowl.
Post A Followup
: Re: Re: Rust in fuel tank
